Corradochris16v
Wing mirror glass
Pull the mirror glass from the four corners one at a time. Carefully and they should pop out from the wing mirror.
once all four corners have popped out there will be two wires on spade connectors for the heated elements which you can undo.
Then you'll need to remove the glass from the backing plate which is stuck together with sticky pads. I just placed them in boiling water for 5 minutes and then carefully separated the two.
Have a look on ebay for the convex heated type. About £10 a side mate. Theres a thread on here about it somewhere. :D
As above.
Search for "Corrado convex mirror" and it should be the first one. Picture is of a mirror saying left or right. You'll obviously need to order 2 (one of each side).
Quality isn't up there with genuine, but it's not bad. Being convex you see much more in them, especially on the drivers side.
