spartacus74 10 Posted July 15, 2012 Hi, I had my car MOT'd a couple of months back, in order to get it through its MOT they had to bodge the ABS light to get it working. Afterwards I found out they'd done this by running a wire from what I assume to be the 12v connection on a relay slot between relays 18 and 21 on the relay board behind the fuse board. I've now taken this wire off, as I want to do it right, however the spoiler hasn't been working since they bodged the ABS light. I've searched on here and it seems the Spoiler control relay is located just above the fuse board and think I can see it with the dash surround out to the right of the dash. Could you look at the first 2 pics and see if you recognise it so I know i've got it right or not? Also i've noticed a white plug above the fuse board that doesn't seem to be connected to anything and wondered if any of you can help identify what it should be connected to? Quote Share this post Link to post Share on other sites
dragon green 5 Posted July 15, 2012 Here's what the spoiler control unit looks like Its fixed to the dash by a hooped metal bracket, IIRC it just lifts out. With the lower shelf out, just put your arm up And you can feel it ! Quote Share this post Link to post Share on other sites
Bumblebee2 10 Posted January 17, 2013 Thumbs up for the detailed spoiler control unit post which helped me locate and clear a similar issue. Quote Share this post Link to post Share on other sites
