Rorgasm 10 Posted August 1, 2012 Here the first of what im sure will be may question for changing bits & bobs on my G60. Would like to change the dash from black to Grey in my 1991 G60 & was wondering if the late model dashboards are the same with different controls in them?? Idealy i would love to change the heater controlls & switches to the later versions but would like to know how big this job actually is before adding it to the for ever growing list i seem to be making myself. Cheers for any help:thumbleft: Rory Quote Share this post Link to post Share on other sites
dragon green 6 Posted August 1, 2012 Late dash will fit in an early ! The centre sections will fit in either, meaning you can have late dash early heater, early dash,late heater ! The heater boxes are slightly different from early to late,easy to change,if you want later switches,headlight is a straight swap,others aren't ! Easier to swap switch looms ! Loads of info if you use the search ! Quote Share this post Link to post Share on other sites
Rorgasm 10 Posted August 2, 2012 Brilliant:-) thanks for that info:thumbleft: Found loads info on how to change fix & change a heater matrix & a little bit on Dashboards when i searched bot on here & google but couldn't find anything conclusive enough to start folking out my hard earnt cash. So thats a great help, thanks. Quote Share this post Link to post Share on other sites
