timmaaah 0 Posted September 20, 2012 My 94 vr has developed a really loud squeal/high pitched buzz from what appears to be the fuel tank. It only makes the noise when the engine is running not just when the ignition is on. It stops when the engine stops too. The pitch doesn't vary much, it just goes a little lower pitched when the engine is under load. Is my fuel pump on the way out? Is it an easy replacement? I managed to get the top of the fuel tank off last night, and could see some plastic bits in all the petrol!! Should I drain/use up the fuel before trying to change it. Is there a 'how to' guide? After doing a search I see reference to 2 pumps? The main one and an uplift one? Or do they come as one unit? Any pointers gratefully received. I changed my fuel filter the other day (and that's made a noticeable difference to the response of the engine) - the old one weighed about 1kg - the new one about 100 grammes :D Quote Share this post Link to post Share on other sites
steVR6 10 Posted September 20, 2012 i'd check if any of the fuel lines are kinked or blocked,was it happening before you changed the filter? Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 20, 2012 just has an in-tank pump, reach in, twist and remove, pretty easy. from your description of the sound I'd say it's pretty poorly, they will get worse as the fuel level drops too. Quote Share this post Link to post Share on other sites
Pete 0 Posted September 20, 2012 New pump time definitely. The bits of swarf in the tank should be blocked by the filter so probably best to change both Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 20, 2012 Sit down before calling the dealer. Quote Share this post Link to post Share on other sites
timmaaah 0 Posted September 20, 2012 steVR6 said: i'd check if any of the fuel lines are kinked or blocked,was it happening before you changed the filter? Yes - it was doing it before I changed the filter - there doesn't appear to be any kinks in the fuel line - they were replaced back in 2007 and the car hasn't done huge mileage since. It's just the one piece assembly then? And horrifically expensive? :( Oh well :) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted September 20, 2012 Mine did this noise for a while, then just stopped making the noise and was fine again for thousands of miles. Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 20, 2012 If it's the one piece pump/level sensor type then a mk3 golf one is the same pump, only difference is the level sensor float arm which can be bent to the right level. I have a second hand golf VR one in my 8v Corrado (which uses the same pump as the VR6 Corrado) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 20, 2012 Except that some MK3 Golf ones are 3 bar. Corrado needs 4 bar. VW have recently changed the pump to a VDO one I believe. Used to be bosch. I enquired about 6 months ago and it was around £200! Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 20, 2012 Yeah, all mk3 gti/16v/vr pumps is what I meant, 2l 8v engines use the 4 bar which surprised me, main thing is it broadens the parts available a bit as the corrado pump with it's sender incorporated is model specific otherwise Quote Share this post Link to post Share on other sites
timmaaah 0 Posted September 20, 2012 Well the list price from VW is £220.18 inc vat but I did get a decent discount (half price ;)). It's a fairly straightforward swap - lift up the carpet - undo the access panel - remove the multi pin plug and the send and return fuel lines - unscrew the big collar - lift off the top plate - twist the pump assembly 20 degrees anti clock wise and then lift the whole lot out. Remove the send and return fuel lines from the old pump. You have to unclip the sender unit/float from the old pump and clip it into the new pump. Refitting is a reversal of removal. It's 100% cleared the problem - no whiny noise any more :) Thanks for the replies :) Quote Share this post Link to post Share on other sites
