Stonejag
Part numbers for door card fixings
Hi all,
I've gained a rattle in my driver's door, and I suspect the (very tired) fittings at the opening end have come loose again. I believe the plastic pop-rivet clips that hold the lower edge of the door card are 3A0 867 301, but what's the part number for the right-angled plastic parts that pop-rivet onto the door skin and accept the self-tapping screws through the edge of the door card?
Also, how many do I need? I only have a couple left and it looks like there should be more...
Cheers :)
this any help?
original image link is here if you need it bigger: http://s8.beta.photobucket.com/user/kayaksurfer_blyth/media/Untitled.jpg.html
parts list for door cards
(1) ---------
no longer available
(1A) ---------
no longer available
- 3A0867201H
protective foil
1100X600X2 /
- AKL43401925
double-sided adhesive tape
19MMX25M /
2 N 90157501
panel screw
B4,2X25 /
(3) 535867131
storage box
left /
535867131 4FB
black
(3A 535867133A
storage box
left /
535867133A 4FB
black
535867133A 9DK
platinum
(3A) 535867134A
storage box
right /
535867134A 4YV
light beige
535867134A 9DK
platinum
- 535831367
retaining bracket / storage box / see illustration:
left 153 /
- 535831368
right 153 /
4 N 0139622
oval head panel screw
ST3,9X16-C /
5 N 0200321
plug
A6X0,8 /
6 N 90157601
oval head panel screw / F >> 50-N-035 000*
B4,2X45 /
(6) N 01396626
oval head panel screw / F 50-P-000 001>>*
4,2X13STC /
(7) ---------
no longer available
(7A) 535867145C
loudspeaker grille
left /
535867145C 4FB
black
7 535867146A
loudspeaker grille
right /
535867146A 4FB
black
7A 535867146C
loudspeaker grille
right /
535867146C 4FB
black
9 191867166A
clips
10 321867169B
cover cap
321867169B 01C
satin black
11 533867170
washer
(12) 535867171
grab handle
left /
535867171 01C
satin black
12A 535867172B
grab handle
right lhd /
535867172B 01C
satin black
(12A) 536867172
grab handle
right rhd /
536867172 01C
satin black
(12A) 536867171A
grab handle
leather left rhd /
536867171A 1BX
black
-VA /
13 N 01414112
fillister hd. bolt
M6X18 /
14 533867299
clip / F >> 50-N-035 000*
(14) N 0154292
snap nut / F 50-P-000 001>>*
ST4,2X16,5X11 /
15 535867299B
clips
16 3A0867301
retainer
3A0867301 01C
satin black
(17) 535868503A
molding for door trim panel
left /
535868503A 01C
satin black
17 535868504A
right /
535868504A 01C
satin black
18 ---------
no longer available
19 171857026A
hexagon nut, shouldered
M5 /
20 ---------
no longer available
22 N 90241203
fillister hd. bolt
M4X20 /
21 N 90282501
Edited by timthetinyhorse
I'd got that far but it's one of the badly scanned pages...
Best quality pic I've found is this:
img.asp@mdl=076&unit=74803C3D
So is it item #15 then? :scratch:
im presuming so yes.......
where did you source that image from?
I knew of a russian site online that had a good parts catalogue that was in better quality but havnt accessed it for a while
I asked at my dealers for some of these about 8 months ago and was met with the usual obsolete answer :(
  fendervg said:
They're still available - it's not a Corrado specific part.
Is there another part number for them other than the 535* one then?
Finally got a chance to do some digging through ETKA at the dealership and ordered some Mk3 Golf bits on the offchance. They fit! You can use 321 867 299 B "clip" as an alternative to the obsolete Corrado part - they're nearly identical but made from uncoloured / white nylon instead of the black plastic used on the originals.
I can finally stop my door cards flapping about! :cheers:
Edited by Stonejag
