jimbob88 10 Posted November 29, 2012 i have conducted a srearch but found no definitive answer to this, my passenger window stopped working a few days ago (in the up postion thank god) and now refuses to do anything. drivers side switch and passenger side switch both produce a voltage drop when the car is running so the switches are good. but there is no noise, clicksm ,sounds of any kind coming from the window itself, is it the control module or the reg? as i said i did a search but no one actually stated what the fix was/is thanks jamie Quote Share this post Link to post Share on other sites
Riley 0 Posted November 29, 2012 Do you have a 12v test light? If so I'd start looking for power in the door at the loom plug (While operating switches) to see if you are getting a voltage for both up and down at the plug. If you are, then the regulator may be knackered/jammed/stuck. If not, then time to work your way back to the control module and check for output voltages there, same idea when up/down operated from the switches. Also, just worth a try...Just pop out the switch in the passenger door, unplug it, and then try operating the window again from the drivers door. Quote Share this post Link to post Share on other sites
dragon green 6 Posted November 29, 2012 Pop the doorcard off and check the mechanism. Sounds to me the cable has broken ! Quote Share this post Link to post Share on other sites
jimbob88 10 Posted November 29, 2012 Thanks for the replies guys, bit of a moot point now tho as i got in the car tonight and the window started working again!! Sods law really as it hasnt worked for at least 2 weeks Quote Share this post Link to post Share on other sites
