twin45
breaking late valver and early valver
do you have the gearbox for the early valver? was it in good condition/what's the milage?
Yer still have it no issues with it 135,000
cheers
Am happy to take the drivers carpet sill trim @ £15 posted
Will just send your email and I will provide my postal address also.
Late spec one has gone but got early spec ones left cheers
Early ones no good mate need a late one to put an oem vdo gauge in, still take the early headlight tho
Hi, do you have the trim that fits on the nearside, on the inside of the door, the black horizontal plastic strip that door card fits next to the door glass for an early valver, probably all the same? Thanks,
Yer £15 posted
hi mate.do you have the plastic rad cover and bracket and fusebox cover in black ??if so how much delivered?cheers.
Edited by dochy
Hi.
Did the heater control unit ever get sold off the late valver? If not are all dials working and fitting tabs still there and how much posted please.
John
Hi
Have you still got the electric window loom n also after pass window switch n surround out of early the early car
if so how much posted
cheers
will
hello m8 have u got a rear number plate plinth m8
ill check condition and get back to you cheers
Have you still got the 9a clocks ? How much posted ?
sure have got 2 sets £40 posted both fully working
cheers
Hi Do you have the late Front bumper, Dashboard,rear door cards, sunroofs, sunroof motor cover, central air vents, RHS interior top door/roof trim, also top plastic door trim just above the door cards, Ashtray with the holder.
