VWVW 1 Posted December 17, 2012 (edited) Does anyone else experience bad condensation inside the car. Its like its got its own micro climate in there. I took my car out for a drive yesterday...parked it up. When I returned 40 min later the cars all steamed up inside to the point you cant see in (could be a non mentioned security feature who needs tinted out windows :). The VR is not my daily drive and have only noticed this during these cold wet days its steams up pretty bad to the point the rear boot windscreen are turing to droplets. Granted my lower boot trims are still to be fitted back after I have taken them off a while ago not sure if that will make a difference. Edited December 17, 2012 by VWVW Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted December 17, 2012 Mine never used to be, but i've noticed it recently. I used to use it about 4-6 times a day, but its just sat for 18months so i'm hoping it will all dry out soon. Quote Share this post Link to post Share on other sites
Portent 0 Posted December 17, 2012 Blocked/damaged foliage seal (passenger side under bonnet by windscreen) allowing water inside? Blocked door drainage holes or damaged/missing inner door membranes allowing water ingress? Heater matrix? Blocked sunroof drain points? Quote Share this post Link to post Share on other sites
matttromans 0 Posted December 17, 2012 I've recently noticed similar, I think i've sorted the problem (leaky windscreen seal), but have ordered one of these to dry the car out. http://www.amazon.co.uk/ThoMar-5217007-Car-Dehumidifier-Air/dp/B000XUPEJY/ref=sr_1_1?s=automotive&ie=UTF8&qid=1355742335&sr=1-1 Quote Share this post Link to post Share on other sites
guildmage 11 Posted December 17, 2012 (edited) I've always been using this from Halffords: http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_169605_langId_-1_categoryId_165745 It's small enough to sit behind my passenger seat. It last's for quite long, once used.. you can buy replacement filling-bag (so no need for new box). Hard to say how well it works I also re-did my indoor membranes, still for the price it's worth giving a shot. edit: Mine rear window does steam a bit... but nowhere even close to see droplets and such (as you describe) so may have diff problem somewhere else. Edited December 17, 2012 by guildmage Quote Share this post Link to post Share on other sites
davidwort 0 Posted December 17, 2012 door membranes are a bu99er, a small opening, even if water doesn't drip into the car, means that water that sits inside the door skin after rain or melted frost, will evaporate and then condense on glass surfaces inside the car Quote Share this post Link to post Share on other sites
James. 7 Posted December 17, 2012 My rear screen does seem to do it quite a bit. But the de-mister seems to work okay. Thing I find, because they're so well sealed, when I get in the car with wet shoes, it has nowhere to evaporate to. Check the seal on the lower part of the screen. I've seen two cars where the metal has rusted through. Because of where it is, it's not always obvious. Quote Share this post Link to post Share on other sites
nipper09 10 Posted December 17, 2012 i noticed exactly the same today when i went back to the works carpark about an hour after parking up. but my mates 09 octavia was worse than my storm and my 08 vw t5 front screen takes ages to clear!!! so i wouldnt worry too much cheers paul Quote Share this post Link to post Share on other sites
scott1980 10 Posted December 18, 2012 Yep ! and it pi55es me off ! haha , think theres a bit of a leak somewhere on mine tho , gonna start with door seals , then windscreen (odd drop creeps through when it lashes down) Quote Share this post Link to post Share on other sites
Craig 0 Posted December 19, 2012 Ha funny you mention this, I said exactly the same thing last week, after parking in tesco and coming out half an hour later all windows were steamed up yet a friends ford focus had perfectly clear windows. Might have to invest in one of those moisture bags. :) Quote Share this post Link to post Share on other sites
bollingtonjohn 10 Posted December 19, 2012 Ive had misting up problem lately and was told at VW Garage the heater matrix may be leaking only it will cost over £700 to replace. Quote Share this post Link to post Share on other sites
davidwort 0 Posted December 19, 2012 the matrix is 40 or 50 quid, plus a day taking bits out from under the dash, it's fiddliy but not rocket-science, either have a go yourself (guide on the forum) or find someone who'll do it for a few quid cash in hand one weekend, you don't need to remove the whole dash. Quote Share this post Link to post Share on other sites
