dil
Removing headlight-rusted screw
The third screw which you get to through the hole in slam panel is rusted? How to get this one out?
Cheers
Cheers
can you get to the head with a junior hacksaw without damaging bodywork ???? I managed to put small straight cuts in the heads of a couple of mine "carefully".... which meant I could use a flat head screwdriver to remove them.....
replace with stainless when you have removed them.
or as above carefully drill them out.
Edited by delfinis38
soak with wd40
then put in the right screwdriver and tap firmly with a hammer
most screw heads are soft so you should not only dislodge the screw threads but also get a firmer bite
cheers paul
