JMC 0 Posted January 7, 2013 Right, for the 1st time in ages I have a problem with the G60. Now as they go this is a small problem, but annoying never the less. The trip counter sits a 0.0 and doesn't chnage. The total mileage goes up as normal, and nothing else seems to have stopped working, but this just sits at zero. Anyone any ideas about how to fix this - is it likely to be the switch in the instrument cluster that is permanently 'on' and therefore making it stay on zero, or could it be something else? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 7, 2013 Good call on a faulty contact switch. If not that, it'll almost certainly be a circuit board fault as it takes the same signal as the main mileage counter afaik. Quote Share this post Link to post Share on other sites
JMC 0 Posted January 7, 2013 Hmm, thanks Kev - thought it would be an 'instrument out' solution... I think I'll be 'living with it' for now. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 7, 2013 I only use it for mpg calculations! Does the MFA trip counter still work or is that stuck at zero too? Quote Share this post Link to post Share on other sites
JMC 0 Posted January 7, 2013 No the MFA still works from memory. I'm like you, I only use the trip computer to work out whether I'm getting similar MPG between refuelling. Suppose I could use MFA on setting 2 for that, and just reset it everything I fill up. Quote Share this post Link to post Share on other sites
dragon green 6 Posted January 7, 2013 Not sure if your odometer is mechanical or not, but this might help http://forums.vwvortex.com/showpost.php?p=77651626 Quote Share this post Link to post Share on other sites
JMC 0 Posted January 7, 2013 Yeah, mines a digital unforunately :( Quote Share this post Link to post Share on other sites
