g60 jack
wipers got a mind of there own
My wipers are going crazy. They sometimes come on on their own :-s when they are ment to be off, and wint stop... I turned the ignition of then back, obviously they stop once the key is out, but as soon as the ignition is back on....away they go again.
Anybody had this problem before or know the solution?
Cheers
I used to drive over a bump and mine would come on !
Mine was an unused "tail" in the fusebox that was arking out on the wiper wiring,
I just cut the unused tail off,and repaired the wiring.this was after I replaced everything,I used to drive with the wiper relay out,only put it in,when raining !
This was about 4 years ago,still ok
