g60 jack 10 Posted January 26, 2013 My wipers are going crazy. They sometimes come on on their own :-s when they are ment to be off, and wint stop... I turned the ignition of then back, obviously they stop once the key is out, but as soon as the ignition is back on....away they go again. Anybody had this problem before or know the solution? Cheers Quote Share this post Link to post Share on other sites
joebloggsVR69 0 Posted January 26, 2013 Stupid question - you sure the stalk is not in the 'intermittant wipe' position? Quote Share this post Link to post Share on other sites
g60 jack 10 Posted January 26, 2013 Ha ha ha ha possitive, im sitting in it now, and they just randomly stoped about 30 seconds ago Quote Share this post Link to post Share on other sites
dragon green 6 Posted January 26, 2013 I used to drive over a bump and mine would come on ! Mine was an unused "tail" in the fusebox that was arking out on the wiper wiring, I just cut the unused tail off,and repaired the wiring.this was after I replaced everything,I used to drive with the wiper relay out,only put it in,when raining ! This was about 4 years ago,still ok Quote Share this post Link to post Share on other sites
g60 jack 10 Posted January 26, 2013 I will check if its the same on mine then. The back wiper does it too sometimes, so I've just diconected that Quote Share this post Link to post Share on other sites
