JimyJonz 10 Posted February 11, 2013 I just managed to get a 150mm BMC CDA for £40 from ebay :dance: now comes the issue of fitting it. Has anyone got a guide or thread they can link me to? I've had a search but couldn't find anything. I'm not very car savvy yet but hoping to learn so if anyone can help me out with exactly how to go about fitting one of these, what additional parts ill need etc I'd be very grateful Thanks Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted February 11, 2013 You need a short length of silicone pipe to fit the CDA to the MAF and a metal bracket to support the CDA from the side of the engine. Did you get the metal collar that goes around the CDA? I believe Stealth Racing stock a fitting kit or at least the correct size silicone pipe. This thread may be of some use - some pics towards the end. http://the-corrado.net/showthread.php?37190-BMC-CDA-how-is-yours-set-up&highlight=BMC+CDA Quote Share this post Link to post Share on other sites
JimyJonz 10 Posted February 11, 2013 Yeah it came with the metal cover, that threads helpful thanks. Any idea what size silicone pipe I need? Cheers Quote Share this post Link to post Share on other sites
Southie 10 Posted February 11, 2013 (edited) 80mm, one of these http://www.merlinmotorsport.co.uk/p9422/SAMCO-STRAIGHT-COUPLING-HOSE-80mm-BORE/product_info.html Edited February 11, 2013 by Southie Quote Share this post Link to post Share on other sites
JimyJonz 10 Posted February 17, 2013 Thanks for the help, it turned up yesterday but previous owner had cut a chunk out of the MAF end and glued what looked like his sensor in there. I managed to get it out without further damage but there's still a chunk of plastic missing about 1.5cm down and 3cm wide from the part the silicone pipe would be around. Should I do anything differently because of this? I also managed to order the pipe in the 3 minutes before the post was edited, so need a slightly smaller one now :bonk: Quote Share this post Link to post Share on other sites
JimyJonz 10 Posted February 20, 2013 Well it's all fitted now, was pretty straightforward but your replies helped a lot. Thanks :-) Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted February 21, 2013 Enjoy :) Quote Share this post Link to post Share on other sites
