GTi.Si 0 Posted March 21, 2013 Hi all. I have been trying to diagnose a running fault on a friends VR6. Its using a lot of fuel, running rough, stalling on idle etc... I've tracked it down to a broken off connector (with the wires!) on the bottom of the dizzy. I believe this is the hall sender. I have found what I think we need to fix it here: http://www.ebay.co.uk/itm/Distributor-Pick-Up-Coil-Pulse-Sensor-Audi-Vw-Seat-Skoda-14054-/400361472031?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Cars+Type%3A2.8+VR6&hash=item5d3767401f Does anyone have any experience or a how to on how to change this? Quote Share this post Link to post Share on other sites
nrc 0 Posted March 21, 2013 Distributors are a little bit fiddly to repair, but they're easy enough to swap out. Perhaps see if you can have someone lend you a known good one and see if the running issue is cured. Quote Share this post Link to post Share on other sites
GTi.Si 0 Posted March 21, 2013 I was thinking that would be the case! Biggest problem is VR6's with dizzys aren't the most common engines! Quote Share this post Link to post Share on other sites
robrado974 1 Posted March 21, 2013 I would put out a wanted ,hallsender needed ,see what you get , at £92.00 you need to make sure ! Quote Share this post Link to post Share on other sites
Lufbramatt 0 Posted March 21, 2013 just rebuilt the dizzy on my ABF. The vr6 one looks pretty similar. Once you get the drive "cog" off the end its pretty simple. replace the oil seal when you're in there too. I'm not sure how you get the cog off a vr6 dizzy but on the abf one you have to knock a roll pin out from the middle which is the hardest bit as it involves a fair amount of force and you have to be careful not to crack the alloy casing. Perfectly do-able though if you're mechanically minded. Quote Share this post Link to post Share on other sites
GTi.Si 0 Posted March 21, 2013 Think ill try and locate a dizzy just incase, then ill have a go at repairing the existing one! Quote Share this post Link to post Share on other sites
