tinsman
turn2 motor mounts
i have the lower front turn2 motor mounts that im trying to get in the car right now and i car across a problem. with the washer in there after i put the second mount on it, the cap thing doesnt fit very will. the bolts barlel fit through the holes and it would be hard to get a nut on there. is this normal??? any sugestions? had anyone had this problem??
never mind... i figured it out and its in... what i was doing wrong is that i didnt really realise that when u take the stock mount it it does actually sink a little bit. so i had to make up my own little axel thing to lift the engine up. just in case anyone has that kind of problem... and the reason it sank... is because i didnt use a jack i just drove it up on 2 ramps. thanks anyway- tj
