VR6Pete 0 Posted April 18, 2013 Hi There, since my OBD2 upgrade, I've got this fault, I think its just a small wiring issue, but I'm just wondering if the active spoiler takes an input from this sensor to raise the spoiler at 55MPH? The reason I ask is because it currently doesn't raise, but works fine off the switch.... Thanks. Quote Share this post Link to post Share on other sites
GrahamU 5 Posted April 18, 2013 I beleive the spoiler speed control is generated of the speedo itself and not from the vss I assume the speedo itself works ok? Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted April 18, 2013 Yeah. Works perfectly. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 18, 2013 Hmmm - Did your OBD2 stuff come from an Automatic by any chance?? Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted April 18, 2013 100% manual, I knew the car it came from :) It the two are not related in anyway way then I know I may need a spoiler module possibly? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 19, 2013 100% manual, I knew the car it came from :) It the two are not related in anyway way then I know I may need a spoiler module possibly? And the ECU? Just I thought that sensor was auto only but maybe it is the one on the gearbox - maybe worth cleaning / reseating the connection Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted April 19, 2013 00281 - Vehicle Speed Sensor (G68) 03-00 - No Signal Is the exact error code, Vince sent me a possible fix that involved joining two wired behind the fuse box, but I just wanted to know is it worth getting a spoiler module if the two are unrealted issues :) Quote Share this post Link to post Share on other sites
GrahamU 5 Posted April 20, 2013 Sound to me that you do have 2 problems the vss is not connected to the engine ecu giving you the error message, join the wires as vince says and the spoiler system module may not be working The vss must be working for the speedo to be working Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted April 23, 2013 Ok great, if it sounds like 2 different problems, then I'll look into buying a new spoiler module, just didn't want to waste time / effort on a module if it took the input from the vss. Quote Share this post Link to post Share on other sites
seanl82 23 Posted November 14, 2013 Pete, do you have the info that Vince sent you still by any chance? I've got an error code of implausible signal with my VSS. My speedo works fine, but my spoiler doesn't go up automatically despite changing the control module and checking stereo wiring. Cheers mate. Quote Share this post Link to post Share on other sites
Mark261288 10 Posted February 11, 2015 Hi, i know this is an old post but I'm having the same fault. What is this possible fix involving the two wires? Thanks Quote Share this post Link to post Share on other sites
