Jonny777 0 Posted May 21, 2013 (edited) Good afternoon all! Just recently picked myself up a Corrado VR6 after being out of the Corrado game for 2 years and was just beginning to assess the little issues i've got. Its a K Reg and at the moment the Coolant temperature gauge isn't working at all. So have been using the Oil temp on the MFA as a guide. Any ideas on what it is that caused it to not work full stop? Is it going to be a sender issue or most likely the dash clocks? Thanks! Edited May 21, 2013 by Jonny777 Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 21, 2013 Would have thought , either relay Inthe wrong place ? See fourth page on posts or find in using the search , or a fuse , or like you said the sender , has to be one of them . Just a process of illimination Quote Share this post Link to post Share on other sites
Jonny777 0 Posted May 21, 2013 I did a search a few days ago and I couldn't find one that didn't work full stop, just that was being erratic. I might have missed one though. Are those things particularly difficult to do/to find? Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 21, 2013 I think the yellow sender is the one for the gauge.Someone will correct me if im wrong . Your senders are found on the front of the block , they are under a plastic cover . You will see a plastic circlip , pull that out and the sender will come out , these have a rubber 'o' ring ,make sure if its not on the end of the sender ,to take it out of the hole as the new one comes with a new ring ,trust me you dont want two in there !.As for the fuses im not sure which one operates this ? or which relay . If you type in temp sender in the search it will come up with the relay problem . Rob Quote Share this post Link to post Share on other sites
Mawrick 0 Posted May 21, 2013 I have been doing a lot of troubleshooting of the temp gauge lately (mine went uo to about 90C when I turned ignition on, and stayed there, even with a cold car). robrado974 is correct, the yellow sensor is the one that goes to the gauge - to be more specific it's the blue/white cable, there is also two ground wires on this connector, and the last one goes to fan control module. The white/blue cable will go all the way to the cluster harness on pin 23 (it's the 28 pin connector harness of your cluster). What I would do as a test (presuming you have a multimeter), check the voltage between ground and the blue/white cable, it should read aprox 10V (with ignition on), the cable for fan-control module should read aprox 12V Also check if there is a relay in position 5 (number 2 from right side in the upper row of relays), I think it should be either a relay 43 or left empty. If there is also trouble with your fuel gauge the voltage stabiliser in the cluster might be causing this....... ---------- Post added at 7:55 PM ---------- Previous post was at 7:16 PM ---------- Thought I'd add a bit more - if the voltage check out fine, I would just try to replace the sensor, if you want to make sure the line is ok, you can connect a wire into the connector and "ohm" it from the pin 23 on the cluster harness. Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 21, 2013 Also , if you are going to change one sender you may as well change all three while your at it Rob Quote Share this post Link to post Share on other sites
Jonny777 0 Posted May 22, 2013 Lovely stuff, well its a start then! Will check into why its not working. Thanks for the advice gents! Quote Share this post Link to post Share on other sites
Jonny777 0 Posted September 4, 2016 Bumping this up as I never got around to sorting it. Finally putting the car back on the road 3 years later. Oops. Does anybody have the part numbers for the sensors I need? Cheers guys. Quote Share this post Link to post Share on other sites
