brian g60 corrado
front camber settings on g60 with coilovers
was wondering what people are setting the camber on the front suspention.
i have a g60 raddo with coilovers just fitted and only lowered about 20-30mm.
any suggestions for geometary settings ,and poss best place to get it done in the heathrow area would be great .
cheers.
brian. :)
it is supposed to be between -1 and -0.2
I have the camber set at - 0.5 degrees, as it is a road car, i guess if your are going to be using it as a track car, u might want some more negitive camber. Too much negitive camber on the road will give quicker tyre ware, and also make the car feel a bit vaugue on the motorway, but for the track, it will turn in a bit better.
That being said, mine is good on the track with the camber angle as it is.
I never had tyre wear issues with my MK1. I used to have that set nearly as far as it would go negative. Although I did track days with it, I used to run 15K on the road a year too.
Gavin
