lard44 0 Posted July 30, 2013 Hi all, Ordered some Apex lowering springs a looooong time ago for my '95 Corrado, finally got around to fitting them BUT the new springs are significantly wider at the top than the old standard springs - as a result the top spring seat could almost slip through the top of the spring itself. It certainly doesn't inspire confidence. The fact is that the springs are hardly even under tension when the strut's out...although it should only be a 40mm drop. Them the springs: http://www.ebay.co.uk/itm/APEX-Lowering-Springs-VW-Corrado-VR6-91-95-/170717226273?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27bf8a2521 I've double-checked the part numbers - they're the right springs apparently. Anyone else had any experience of these? I'm not sure if I want to refit it as is if I can't be sure the spring's not going to unseat itself and pop through the top mount! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 30, 2013 VR6 I assume? They had 2 different size top caps depending on year. I think 94 onwards got the larger top cap, which is what you need to order from VW or scour off ebay! Quote Share this post Link to post Share on other sites
lard44 0 Posted July 30, 2013 Hmmm...mine's on an 'M' plate but definitely hasn't got big enough caps...any idea how big 'bigger' is so I can measure what I've got...fnarr fnarr... Quote Share this post Link to post Share on other sites
