delfinis38 1 Posted September 3, 2013 Does anyone know the correct spec for gearbox oil on a manual box on a vr. Nothing in the owners manual. I know lots use the redline mt90 which is fully synth 75w90, castrol website suggest the same spec castrol syntrans 75w90. However opie oils suggest 80w. Anyone used the Castro syntrans stuff. Not sure what to use... Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted September 3, 2013 Used the castrol several times and it's good. Can get it in halfords too. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted September 3, 2013 Used the castrol several times and it's good. Can get it in halfords too. Yup spotted that on the halfords web page. Was very temped as I can do it tomorrow. Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted September 3, 2013 Used the Castrol in every car so far with no problems. Ian. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted September 4, 2013 Mt 90 went in mine. The old stuff was very icky so im glad I did! Quote Share this post Link to post Share on other sites
ChrisL 20 Posted April 14, 2014 I need to fill my gearbox back up, is the Castrol Syntrans 75W-90 from Halfords the right stuff please? Also, how much do I need? Quote Share this post Link to post Share on other sites
seanl82 23 Posted April 15, 2014 Used Redline Mt90 too. Uses just under two Us quarts, so two litres is enough Chris. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted April 15, 2014 I need to fill my gearbox back up, is the Castrol Syntrans 75W-90 from Halfords the right stuff please? Also, how much do I need? chris if you want the correct spec the Castrol syntrans is what you need... but not the multivehicle stuff Halfords sell. I made the mistake buying it. you need the syntrans transaxle... I bought mine from opie oils ebay... http://www.ebay.co.uk/itm/Castrol-Syntrans-Transaxle-75W-90-Synthetic-Transmission-Fluid-75W90-1-Litre-1L-/181234163972?pt=UK_Vehicle_Oils_Lubricants_Fluids&hash=item2a3265e104. you need 2 pots takes about 1.5 litres. if you want to double check like I did Castrol website is your friend... type your reg in. the transaxle stuff is the correct vw 505 or whatever the spec is for the car...... red line is also okay.... again you need 2 pots Quote Share this post Link to post Share on other sites
ChrisL 20 Posted April 15, 2014 Just got a price from TPS for the gear oil, its £5.76 per litre. Cheaper then the castrol stuff. Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 15, 2014 Just got a price from TPS for the gear oil, its £5.76 per litre. Cheaper then the castrol stuff. yes, but that isn't the synthetic oil, VW's own synthetic gear oil is a lot more and rarely stocked, usually have to wait a while for special order Quote Share this post Link to post Share on other sites
ChrisL 20 Posted April 15, 2014 Am I best to avoid this gear oil then? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 15, 2014 Am I best to avoid this gear oil then? Just ask what the spec is... TPS are usually competitive on Oil and they now sell Castrol also... Quote Share this post Link to post Share on other sites
ChrisL 20 Posted April 15, 2014 Thanks guys, bought some castrol from opie Quote Share this post Link to post Share on other sites
Jamie 1 Posted April 15, 2014 chris if you want the correct spec the Castrol syntrans is what you need... but not the multivehicle stuff Halfords sell. I made the mistake buying it. you need the syntrans transaxle... I bought mine from opie oils ebay... http://www.ebay.co.uk/itm/Castrol-Syntrans-Transaxle-75W-90-Synthetic-Transmission-Fluid-75W90-1-Litre-1L-/181234163972?pt=UK_Vehicle_Oils_Lubricants_Fluids&hash=item2a3265e104. you need 2 pots takes about 1.5 litres. if you want to double check like I did Castrol website is your friend... type your reg in. the transaxle stuff is the correct vw 505 or whatever the spec is for the car...... red line is also okay.... again you need 2 pots Hmmmmm... When I emailed Opie and asked their advice on gear oil they recommended (and I bought) the 75-90 Multi Vehicle Quote Share this post Link to post Share on other sites
delfinis38 1 Posted April 15, 2014 Don't think there is much difference. It's just not to vw spec. I was unsure so rang castrol and asked. Quote Share this post Link to post Share on other sites
