Bullfinch 0 Posted September 5, 2013 I've resurrected my Corrado after 2+ years in storage and in the boot was stored all my cleaning products. Lots of Autoglym and Meguirs stuff - waxes, polishes, clay bar etc. I can't see any mention of an expiry date on the bottles - hence I assume they are good to use? Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted September 5, 2013 Yeah they'll be fine! unless they come out as powder :bonk: Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted September 5, 2013 Give em a good shake and test on a part u can't see or test panel. Quote Share this post Link to post Share on other sites
seanl82 23 Posted September 5, 2013 They don't have a shelf life, but chemical parts can separate after time. A good shake should see them ok again if as mentioned, they haven't turned to powder. Quote Share this post Link to post Share on other sites
DiamondTony 10 Posted September 5, 2013 They should be fine if they're left, as long as the bottles were properly closed before they went in. Make sure when you polish the car to shake the bottle, and remove all sediment from the cap as the bits will scratch the paint work. Also seal the polish in with a sealant before waxing to preserve the paint ;) Quote Share this post Link to post Share on other sites
Bullfinch 0 Posted September 6, 2013 Many thanks. Saves me a few pennies:) Quote Share this post Link to post Share on other sites
VR6 0 Posted September 6, 2013 Does the same go for lube? Quote Share this post Link to post Share on other sites
EJ Taylor 22 Posted September 6, 2013 Does the same go for lube? Bin it and GO IN DRY! Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted September 6, 2013 Spit..... gods lube! Quote Share this post Link to post Share on other sites
DiamondTony 10 Posted September 6, 2013 Spit..... gods lube! Hahaha! Awhhh yisssss Quote Share this post Link to post Share on other sites
