tom_rob_89
double window switch
Hi all just wondered if it is just a quick swap to change my drivers side window swich from a single to a double. I have a '96 car and would have though that it should have a double one anyway?
cheers Tom
Is the wiring there?
To me, it sounds like someone has swapped the door card for a LHD to have just one switch,
If your lucky the wiring and connector will be tucked in behind the panel.
Thanks for your replys.
This is what the back of the switch looks like and there isnt any other wires not pluged in
[ATTACH=CONFIG]75574[/ATTACH]
Also any idea what this connector is supposed to be for at the other end of the door?
[ATTACH=CONFIG]75577[/ATTACH] [ATTACH=CONFIG]75576[/ATTACH]
