Ray1965 10 Posted October 19, 2013 Are these any good? :shrug: http://www.ebay.co.uk/itm/SPARK-PLUG-Removal-Spanner-Wrench-Tool-for-VW-CORRADO-10-14mm-16-21mm-Euro-/280854613797?pt=LH_DefaultDomain_3&hash=item41643d4f25 Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 19, 2013 I bought the lead removal tool on its own from ebay , works fine , just had to close the end up a bit tighter as the plug can sometimes slide up when pushing them on . This one should be fine too . Quote Share this post Link to post Share on other sites
delfinis38 1 Posted October 19, 2013 (edited) robrado974 said: I bought the lead removal tool on its own from ebay , works fine , just had to close the end up a bit tighter as the plug can sometimes slide up when pushing them on . This one should be fine too . don't think it does leads.... it just prevents you having to have an assortment of extensions on a socket that fall apart when removing the plug..... I normally tape my extensions and socket together and they still fall apart. my only question would be is it long enough to get through the v6 engine plastic Edited October 19, 2013 by delfinis38 Quote Share this post Link to post Share on other sites
Dox 28 Posted October 19, 2013 delfinis38 said: don't think it does leads.... it just prevents you having to have an assortment of extensions on a socket that fall apart when removing the plug..... I normally tape my extensions and socket together and they still fall apart. I use extensions with the buttons on the side to depress and release the socket http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_170565_langId_-1_categoryId_165469 Useful for other applications too where you don't want to drop a socket into a void Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 19, 2013 I have the spark plug socket in my tool kit , with one extension , because of the rubber grommet thingy in the end it grips the plug . Have a look at removal tool only on fleabay . Quote Share this post Link to post Share on other sites
delfinis38 1 Posted October 19, 2013 robrado974 said: I have the spark plug socket in my tool kit , with one extension , because of the rubber grommet thingy in the end it grips the plug . Have a look at removal tool only on fleabay . its not the gripping of the plug. when you have nipped it up and you try and remove socket and extensions that don't have the locking pip like dox has suggested your sockets is normally left on the plug and you just remove the extension and ratchet. Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 19, 2013 Sorry with you now , yep i went and got a more expensive ratchet with the little ball bearings in the heads . Quote Share this post Link to post Share on other sites
VW_chris 10 Posted October 19, 2013 peronally, wouldnt put that near my plugs. lets say for example that pressed metal tool were to round one of my spark plugs, i wouldnt be too happy to say the least... nothing wrong with investing in tools, pay some money for some decent kit, doesnt have to be snap on, halfords advanced is just as good ive found, even better price wise and it will last longer than you will have the car if you look after it. also not really related to the post, i keep a small tool box in my boot full of "corrado" essentials, ive got RAC cover, however, i cant really be towed with a 90mm splitter and coilovers. Quote Share this post Link to post Share on other sites
Jim 2 Posted October 19, 2013 I bought a similar device to that from Halfords some years ago to do the plugs on my 2.0 16v - literally the first time I used it, on the very first plug, the spark plug was in so tight the tool simply bent out of shape as it was made of such soft metal. Total waste of money. Get a proper spark plug socket for your socket set. Quote Share this post Link to post Share on other sites
