agb1980 10 Posted November 24, 2013 Ive searched previous posts for some info on the door seals, can find quite a lot on the scrapers but not much on the door window seal (on the outside around the top of the door) Mine have started to crack towards the bottom and theres corrosion underneath do these seals have metal inside (same as scrapers)or will the door frame itself be corroded? Thanks, Andy Quote Share this post Link to post Share on other sites
easypops 8 Posted November 25, 2013 Fairly sure they are just rubber, and that it's your door that's rusting......got a similar issue on mine......got a replacement door to put on at some point too :) Quote Share this post Link to post Share on other sites
agb1980 10 Posted November 25, 2013 Oh, thats not good. Looks like i might be needing 2 mystic blue doors then...:( Quote Share this post Link to post Share on other sites
