agb1980
Door window seal cracking
Ive searched previous posts for some info on the door seals, can find quite a lot on the scrapers but not much on the door window seal (on the outside around the top of the door)
Mine have started to crack towards the bottom and theres corrosion underneath do these seals have metal inside (same as scrapers)or will the door frame itself be corroded? Thanks, Andy
Fairly sure they are just rubber, and that it's your door that's rusting......got a similar issue on mine......got a replacement door to put on at some point too :)
