MikeVR6 0 Posted May 20, 2004 Does anyone know what this is? The chap who does my mechanical work for me has told me it's throwing up an error on the diagnostic computer intermittantly. Any idea of part number and price would be appreciated. Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted May 20, 2004 look on my avatar. it's the black dot to the right of the oil filter housing. I reads a toothed wheel on the crank and tells the ECU where the crank is at so it knows when to fire. if it's f*cked the engine won't run. about £140 from the dealers. try a bosch dealers and see if it's cheaper. Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted May 20, 2004 oh, and it'll always throw up an error code if you run the diagnostics with the engine off. clear it, and run it with the engine running. I bet it goes away. G28 vehicle speed sensor by any chance? Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted May 20, 2004 Yup that's the error... "G28 Vehicle Speed Sensor - No Signal" He's a qualified VW techy, so he knew to test it with the engine going :) £140 is a bit pricey, don't suppose you have the VW or Bosch part no Phat? Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted May 20, 2004 If it says no signal then it shouldn't be running! in fact, it can't run without a signal from the crank sensor. I certinaly woulsn't buy a new one going off that info mate. Tell him to clear the codes, start the engine, then run anoter test, I bet it doesn't come back up, it can't. Part number on mine is 021 906 433 C bosch number 0 261 210 105 does the engine run OK? At the very least, I'l take the sensor out and clean it up and clean the lbock and efit it agin to see if the rror goes away. but otherwise Id ignore if it runs. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted May 20, 2004 Quite - the ECU *will not open the injectors OR fire the spark plugs* if it's receiving no signal from the engine speed sensor. Phat's spot on there... Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted May 20, 2004 Hmmm, Think I'll give it a wee clean then :) Thanks guys! 8) Quote Share this post Link to post Share on other sites
