Alty 10 Posted December 20, 2013 Hi, have early style heaters, drove home working woke up this morning not working! fuse and relay is fine.......? Quote Share this post Link to post Share on other sites
davidwort 0 Posted December 20, 2013 what's wrong, the blower fan or no heat coming through from the matrix at all? (i.e. no warm air with vents open and driving along) Quote Share this post Link to post Share on other sites
Alty 10 Posted December 20, 2013 I have air flowing from what naturally seeps out But I have nothing no noise from heaters no blowers basically 1-4 doesn't work full stop, the back light is still working though ? Quote Share this post Link to post Share on other sites
Dox 28 Posted December 20, 2013 Check for voltage at the blower fans wiring plug Quote Share this post Link to post Share on other sites
davidwort 0 Posted December 20, 2013 drop the passenger dash shelf, might need to remove the abs ecu cover to the left first, squeeze and un-plug the fan power connector, hunt around the base of the fan housing for the little tab that sticks out, lift it/bend it down and twist the motor to remove. spin the fan blades by hand to see if it is stiff. If you have a multimeter or test light, see if there is power to the plug with the ignition and fan switch on. Should give you an idea of what is up Quote Share this post Link to post Share on other sites
Alty 10 Posted December 20, 2013 Thats my weekend job then! haha. thanks for the advice :) Quote Share this post Link to post Share on other sites
borders16v 0 Posted December 21, 2013 Can I jump in here.Does the heater have its own connection to the battery. Mine stopped working and i suspect my battery connectors.Thanks Quote Share this post Link to post Share on other sites
Diamond Hell 0 Posted December 24, 2013 no, comes from the main fusebox. Quote Share this post Link to post Share on other sites
