Alty
Another heaters not working thread!
Hi, have early style heaters, drove home working woke up this morning not working! fuse and relay is fine.......?
what's wrong, the blower fan or no heat coming through from the matrix at all? (i.e. no warm air with vents open and driving along)
I have air flowing from what naturally seeps out But I have nothing no noise from heaters no blowers basically 1-4 doesn't work full stop, the back light is still working though ?
drop the passenger dash shelf, might need to remove the abs ecu cover to the left first, squeeze and un-plug the fan power connector, hunt around the base of the fan housing for the little tab that sticks out, lift it/bend it down and twist the motor to remove. spin the fan blades by hand to see if it is stiff. If you have a multimeter or test light, see if there is power to the plug with the ignition and fan switch on. Should give you an idea of what is up
