robrado974
Annoying handbreak tunnel problem
While some of my interior is out i thought i would fit the annoying handbreak tunnel solution . It must have taken me ten minutes if that to fit it and its great , nice and tight now . The problem is the handbreak cover is broken where it fixes on to it , so its moving about . Any body else had this problem and fixed it ?, double sided tape ? . Or should i just try and find another one thats undamaged in the wanted section .Thanks Rob
Thanks Sean , mine is black so that's fine , hope I won't fall over at the price though ! . If it's to much I will put up a wanted ad.
Rob
I'm sure I bought one a couple of years ago and it wasn't cheap, but it wasn't ludicrous either - in the sort of £20'ish range.
