fla
rear suspension height
Puzzling one - my rear suspension sits about 10mm higher on the passenger side than the drivers side. Its currently on Koni TAs and Nothelle springs. Does anyone else have the same height issues? If so, how did you resolve this?
Yes very common. The fix is to move the circlip up 2 notches on the driver's side. I asked Vince about it years ago and he thinks it's because the bulk of the fuel tank and engine block weight are all on that side of the car.
OK thanks for that. Mine are without the slots for the different heights though, I've got some spacer collars which are 15mm (iirc).
In fact I've just measured the heights (albeit on a not very flat surface) and the difference is more like 20mm! And about 7mm at the front
