rishi 0 Posted March 26, 2014 Hi all, im getting very stressed now as my corrado VR6 (1995)is starting then cutting out its intermittent. 1. I thought it was immobiliser so I wd40'd the 3 pin connector behind dash (transponder box connector)then drove for a day. 2. problem happened again so took all dash undertrays and say a bodged up alarm so had someone out to remove it. started and drove fine for 2 days. 3. problem happened again. so I ordered a new ecu relay (109) but its still not starting fault code is saying engine start blocked by immobiliser. any ideas? as im off road AGAIN and feel like setting the car on fire lol. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted March 26, 2014 could it possibly be something to do with the immobiliser collar around the ignition that is not communicating with the immobiliser itself IIRC someone on here had a similar issue & it turned out to be a fault with the wire which goes from the collar to the fuse board Quote Share this post Link to post Share on other sites
rishi 0 Posted March 26, 2014 ok sounds like it could be, can anyone shed any light on this? Quote Share this post Link to post Share on other sites
Dox 31 Posted March 26, 2014 Tried your spare key? If you have more than one car key on the same keyring remove it as the immobiliser could be reading the wrong key Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted March 26, 2014 Tried your spare key? If you have more than one car key on the same keyring remove it as the immobiliser could be reading the wrong key good point Dox if there are more than 1 key & they have different code chips in them it will cause the engine to start & then cut out - i had this when i changed my ignition barrel FYI if it is related it should be possible to split the plastic part of the key & swap the chip over ;) Rishi - if you do a search on here there was a recent post about the collar....in fact ive found it as i had posted on it - try this http://the-corrado.net/showthread.php?t=85523 Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 27, 2014 There's also an issue where the reader coil's plug corrodes where it connects to the control box. Trace it back and clean/reseat the connection. Quote Share this post Link to post Share on other sites
rishi 0 Posted March 28, 2014 okay checked all wiring and the car is now running (SO HAPPY) BUT... fuse 19 keeps blowing the 30 amp one for the rad fans, any ideas on this one? dvla should have corrados as tax exempt as every time you want to drive it something goes wrong the corrado wants to slap you in the face and say leave me alone lol Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 28, 2014 Its true, even after replacing most of mine, it still seems to go wrong, even the bits i've replaced need replacing :( Quote Share this post Link to post Share on other sites
rishi 0 Posted March 28, 2014 ok I have jjust removed the fan control module (black rectangular box next to expansion tank) and it rattles like there are a few things loose inside... also does anyone know how to wire up the fan to a switch on the dash? I have done a search but cant find a guide that tells you how its done. Quote Share this post Link to post Share on other sites
rishi 0 Posted March 28, 2014 Ok I got another module off a mk3 vr6 plugged in and went for a long drive, still blowing the 30amp fuse 19. Fans not kicking in either. Really stressing now as the last thing I want is overheating. Also forgot to mention is few months ago the battery was catching the fan and burst battery acid all over the bay, since then the fan was on from start up until I parked it up just before the immobiliser problems Quote Share this post Link to post Share on other sites
rishi 0 Posted March 28, 2014 Also looked at the cooling guide and checked the fans by bridging the rad switch terminals with the common terminal but no joy, then to check stage 3 I bridged the terminals of the black sender on the thermostat housing and the stage 3 worked. I'm so confused right now Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted March 28, 2014 have you checked the fan wiring for any damage/splits? Quote Share this post Link to post Share on other sites
rishi 0 Posted March 29, 2014 yes I did check but im going to have a deeper look as it was raining yesterday. drove it today and I could hear the stage 3 fan kick in at 100degrees. I swear a ghost lives under my bonnet lol Quote Share this post Link to post Share on other sites
rishi 0 Posted March 29, 2014 just checked all wiring. WHAT A MISSION!! all taped back up but couldn't find any problems with wiring.. any ideas? Quote Share this post Link to post Share on other sites
rishi 0 Posted May 27, 2014 car has been working but the problem happened again, was driving and got pulled by the police, once I sat back in my car to drive away it didn't start so had to get towed home. I have tried a different ecu as my diagnostic scanner isn't connecting (link error) but even with the new ecu it turns over but wont fire, any other suggestions before I smash it up with a sledge hammer and burn it? lol Quote Share this post Link to post Share on other sites
maff 10 Posted May 27, 2014 I would definatly hand the car over to an electrical expert/mechanic that will sort it for you, if anything like this needs doing with my cars i just pass it on and hand them £££ Quote Share this post Link to post Share on other sites
Ray1965 10 Posted May 27, 2014 I would definatly hand the car over to an electrical expert/mechanic that will sort it for you, if anything like this needs doing with my cars i just pass it on and hand them £££ I'd be inclined to agree with Maff. Given the amount of problems you have i would take in to a car trish to go through the wiring with a fine toothed comb. Quote Share this post Link to post Share on other sites
