VR6 Lee 0 Posted April 20, 2014 I am going to start the VR up this week after 7 months of winter work. Is there anything worth doing or should you just crank it over Quote Share this post Link to post Share on other sites
seanl82 23 Posted April 20, 2014 I'd crank it over with fuel pump relay removed or something, so it doesn't figure up, just to ensure oil pressure has built up properly. Unless it has minimal fuel, a bit of fresh would help too, otherwise you should be ok. Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted April 22, 2014 Started up perfect.. :))) Quote Share this post Link to post Share on other sites
nipper09 10 Posted April 24, 2014 Hi Lee my battery on my 'vr was dead. charged it up now the alarm goes off soon as I open door. And obviously want start with alarm going. Any ideas? Cheers paul Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted April 24, 2014 I would put key in ignition and then connect battery and see if that works Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted April 24, 2014 Waht alarm have you got nipper, either the battery is totally dead and upsetting the alarm or you need to do a procedure with the alarm buttons usually found in the manual Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted April 24, 2014 I think it's a imbolizer issue. Hence connecting battery with key in ignition.. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted April 24, 2014 VR6 Lee said: I think it's a imbolizer issue. Hence connecting battery with key in ignition.. Thats not going to stop the alarm though is it? Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted April 24, 2014 Registers the key(imobilizet) with the alarm system.Worked on my BMW 5 series so could work Quote Share this post Link to post Share on other sites
nipper09 10 Posted April 24, 2014 Cheers all for the assistance. Would have started Lee's way if battery had enough power. Will charge again and put key in first. cheers pal. Quote Share this post Link to post Share on other sites
