Hawkesybaby 10 Posted April 25, 2014 My heat blower speed only works on full blast setting 4. 1,2 and 3 nothing happens and the works full blast on setting 4. any ideas as to what could be causing this? Easy fix for a common problem? L reg vr6 Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted April 25, 2014 Easy fix, there is a resistor on the fan unit itself that burns out. Swap it for a 70p maplin resistor and job done. I'm on my phone so can't help anymore. Stick vw fan resistor into Google and see what you think. Quote Share this post Link to post Share on other sites
Hawkesybaby 10 Posted April 25, 2014 Awesome! Thanks! Is the motor easily got to or is it a dash out jobby??? Thanks Quote Share this post Link to post Share on other sites
Jim 2 Posted April 25, 2014 Easy. You need to remove the plastic trim underneath the glovebox and around the footwell. The heater motor is on the left hand side - will possibly have a Valeo sticker on it and you should see a four cable square electrical connector attached to it. There is a tab / latch you'll need to release which is, rather awkwardly, round the back but then you just turn it (can't remember whether it's anti or clockwise) and it just drops out. Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted April 25, 2014 You just need to be a contortionist to get down there! Quote Share this post Link to post Share on other sites
Hawkesybaby 10 Posted April 25, 2014 I'll get the missus to do it then..... wheeeeeey! Is the part I need attached the blower motor or the connection? Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 25, 2014 http://wiki.the-corrado.net/fan_speed_thermal_fuse_repair.html Quote Share this post Link to post Share on other sites
Hawkesybaby 10 Posted April 25, 2014 http://wiki.the-corrado.net/fan_speed_thermal_fuse_repair.html Legend! Thanks! Quote Share this post Link to post Share on other sites
Hawkesybaby 10 Posted May 11, 2014 so I went change the resistor and came across this fan.... its completely different to the ones ive seen picture's of and also different to the guide? Anyone got ideas? Its a spal one and looks like it isnt the right one as it wasnt fitted very well at all! Help please peeps Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 11, 2014 That's an air con fan isn't it? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 11, 2014 http://www.ebay.co.uk/itm/Genuine-VW-Corrado-Aircon-Motor-Fan-NEW-/400220333427?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d2efda573 This is the factory one but maybe yours is a Davia supplied one? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 11, 2014 Pics of Diavia one on this thread - looks similar... http://www.the-corrado.net/showthread.php?t=58043&page=3 Quote Share this post Link to post Share on other sites
Hawkesybaby 10 Posted May 12, 2014 There is a Diavia sticker on my door sill! but it still looks different than the one i have.... it was only held in with one screw it didnt look to fit well basically? This is annoying as whats gone from a cheap easy fix to a possible new blower motor haha old cars ay! Any more for any more??? Quote Share this post Link to post Share on other sites
fla 9 Posted May 12, 2014 Yes, that's a diavia one. if it came out easily then it wasn't fitted properly! It is a nightmare to remove and then refit - you need to make sure it seals properly else all the air from the fan will blow through the gap between the plastic flange and the housing of the air handling unit. They're not the best at moving great volumes of air at the best if times hence why it is important to minimise leakage. Quote Share this post Link to post Share on other sites
Hawkesybaby 10 Posted May 13, 2014 How do i get inside the fricking thing!!!!!!????!!!! I cant open it up to change the resistor!!! anyone done this before? anyone local can help? doing my nut in lol! Quote Share this post Link to post Share on other sites
Hawkesybaby 10 Posted July 27, 2014 So after a good few weeks ive had a local auto electrics place replace the thermal fuse and yesterday after a few hours and a sliced open thumb put it all back together and guess what...... it STILL DOESNT WORK!!!!! i literally at my whits end with this!!!! What else could it be??? HELP! Quote Share this post Link to post Share on other sites
fla 9 Posted July 27, 2014 http://the-corrado.net/showthread.php?t=47180 Quote Share this post Link to post Share on other sites
Hawkesybaby 10 Posted July 27, 2014 http://the-corrado.net/showthread.php?t=47180 saw this just after i posted this!!! Great fix! well its works on 2, 3 and 4 now haha! Quote Share this post Link to post Share on other sites
