shaunje 10 Posted May 27, 2014 Well, this is the first forum I've been on that doesn't seem to have an electrical section! MY indicators are not right. One minute they'll be fine, the next minute they wont flash; the light on the dash cluster stays permanently illuminated and the lights don't light up at all. If I press the hazard light switch on and off, then try the indicators again they work fine as if they've been 'reset' for a little while. Any one else had this?! Quote Share this post Link to post Share on other sites
shaunje 10 Posted May 27, 2014 It's NOT the relay. The relay has been replaced anyway. Quote Share this post Link to post Share on other sites
Dox 28 Posted May 27, 2014 I'd be checking and cleaning all earth points near the light units front and rear. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted May 27, 2014 The switches/stalk can go faulty and usually overlooked. also i was certain we had an ice and electric section Quote Share this post Link to post Share on other sites
dragon green 6 Posted May 27, 2014 It only takes one bad bulb to cause this fault ! As said,check all earths,take out indicator bulbs,check and clean Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted May 28, 2014 sounds like an earth problem. Quote Share this post Link to post Share on other sites
shaunje 10 Posted May 31, 2014 I dont think it's related to the bulbs/bulb holders or wiring to the bulb holders as the hazard lights function perfectly. This leaves me to think it is probably the stalk unit at fault? Quote Share this post Link to post Share on other sites
shaunje 10 Posted June 1, 2014 fuse 17 keeps blowing... cant work out why. it's fine if i leave it sat there with the indicators on, but as soon as i drive it and indicate, the fuse blows. anyone able to help at all? it's properly ****ing me off. Quote Share this post Link to post Share on other sites
Andy R32 10 Posted July 19, 2014 Did you fix this - I'm having the same issue. Quote Share this post Link to post Share on other sites
