lion
door locks and pins
I need a bit of help. Both of my doors the door pins have been pulled out. How do I fit them back on. I have removed the door cards but see what the metal rods are ment to connect to
I've got some rods arriving this week hopefully, so if no one has responded by then I will be fitting mine and can do some pics.
They're the clips that are broken on mine. Anyone know where I can get 2 new ones
Still avalible at tps . Around 75p each i think .
Ooo nice - i have this issue on the gf's storm drivers door
having attempted a fix & given up im a tad mistified how you would fit them tho lol
Nice 1, dont suppose u have a part number, and is the passanger side and driverside the same?
Part numbers below, Google the part number for an image. It's a plastic clip which slides onto a lever to the back of the door latch mechanism, the rod then clips into the plastic clip.
357837083 ............ Left
357837084 ............ Right
Edited by leon263
winner thank you kindly leaon263!
Given tps a call and ordered the right side, but the left side is obsolete, anybody know where else I can look for 1.
Thanks
another candidate for 3D printing I reckon
If only I could get the first project actually moving.. :|
Mine was broken on the drivers side, so I placed the rod in the correct location, and used two small cable ties tho hold them together. Still works perfectly. :) You'll need to remove the doorcard to get to it, but I would also recommend removing the door handle too, makes it easier. :)
