lion 0 Posted May 28, 2014 I need a bit of help. Both of my doors the door pins have been pulled out. How do I fit them back on. I have removed the door cards but see what the metal rods are ment to connect to Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted May 28, 2014 I've got some rods arriving this week hopefully, so if no one has responded by then I will be fitting mine and can do some pics. Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 28, 2014 (edited) there's a small plastic clip that the rod is inserted into at an angle, a tab or two breaks off it rendering it useless and the rod falls out second image in the top post on p9: http://the-corrado.net/showthread.php?t=12282&page=9 Edited May 28, 2014 by davidwort Quote Share this post Link to post Share on other sites
lion 0 Posted May 28, 2014 They're the clips that are broken on mine. Anyone know where I can get 2 new ones Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 28, 2014 Still avalible at tps . Around 75p each i think . Quote Share this post Link to post Share on other sites
g0ldf1ng3r 13 Posted May 29, 2014 Still avalible at tps . Around 75p each i think . Ooo nice - i have this issue on the gf's storm drivers door having attempted a fix & given up im a tad mistified how you would fit them tho lol Quote Share this post Link to post Share on other sites
lion 0 Posted May 29, 2014 Nice 1, dont suppose u have a part number, and is the passanger side and driverside the same? Quote Share this post Link to post Share on other sites
leon263 0 Posted May 29, 2014 (edited) Part numbers below, Google the part number for an image. It's a plastic clip which slides onto a lever to the back of the door latch mechanism, the rod then clips into the plastic clip. 357837083 ............ Left 357837084 ............ Right Edited May 29, 2014 by leon263 Quote Share this post Link to post Share on other sites
g0ldf1ng3r 13 Posted May 30, 2014 Part numbers below, Google the part number for an image. It's a plastic clip which slides onto a lever to the back of the door latch mechanism, the rod then clips into the plastic clip. 357837083 ............ Left 357837084 ............ Right winner thank you kindly leaon263! Quote Share this post Link to post Share on other sites
lion 0 Posted June 9, 2014 Given tps a call and ordered the right side, but the left side is obsolete, anybody know where else I can look for 1. Thanks Quote Share this post Link to post Share on other sites
davidwort 0 Posted June 9, 2014 another candidate for 3D printing I reckon Quote Share this post Link to post Share on other sites
Jim 1 Posted June 9, 2014 another candidate for 3D printing I reckon If only I could get the first project actually moving.. :| Quote Share this post Link to post Share on other sites
j_s14a 0 Posted June 9, 2014 Mine was broken on the drivers side, so I placed the rod in the correct location, and used two small cable ties tho hold them together. Still works perfectly. :) You'll need to remove the doorcard to get to it, but I would also recommend removing the door handle too, makes it easier. :) Quote Share this post Link to post Share on other sites
