peterdinosaur 10 Posted June 16, 2014 So MOT this week and the ABS has decided not to work at all! I put the reader on it and it comes up with inlet/outlet failure on all 4 corners (I can check the codes later if needed). Is this pump failure symptoms? Or is it something easier then that? If it is pump failure does anyone know if you can use the valver pump, or has a VR6 ABS pump available! Thanks Peter Quote Share this post Link to post Share on other sites
Dox 23 Posted June 16, 2014 All the 4 cyl pumps I've seen are 4 hard lines in / out, VRs are 6 hard lines in / out Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted June 16, 2014 Fuses and relays are your first port of call I would think. Someone will know which ones....... RB Quote Share this post Link to post Share on other sites
robrado974 1 Posted June 16, 2014 Mine came on the other day , vagcom came back with , no 12v feed to pump . Got it cleaned up , reconnected and all was well . Quote Share this post Link to post Share on other sites
peterdinosaur 10 Posted June 16, 2014 Thanks for the replies, my codes do specify the inlet and outlet valves as the issue? Nothing about the 12v feed and I checked the cabling and looks very clean (which did surprise me). Anything on the relay/fuses to check? Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted June 16, 2014 Abs ecu behind lower passenger side plastic sometimes theres water ingress Quote Share this post Link to post Share on other sites
