peterdinosaur
ABS Faults
So MOT this week and the ABS has decided not to work at all!
I put the reader on it and it comes up with inlet/outlet failure on all 4 corners (I can check the codes later if needed).
Is this pump failure symptoms? Or is it something easier then that?
If it is pump failure does anyone know if you can use the valver pump, or has a VR6 ABS pump available!
Thanks
Peter
All the 4 cyl pumps I've seen are 4 hard lines in / out, VRs are 6 hard lines in / out
Mine came on the other day , vagcom came back with , no 12v feed to pump . Got it cleaned up , reconnected and all was well .
Thanks for the replies, my codes do specify the inlet and outlet valves as the issue? Nothing about the 12v feed and I checked the cabling and looks very clean (which did surprise me).
Anything on the relay/fuses to check?
