fla
OBD2 engine and injectors looms
OBD2 loom, both sides, (fusebox to main connector and main connector to injectors)
Needs tidying up as the old cut wires are still in place. Ideally should be re-wrapped. I've started sorting it out but you will need your aux water pump connector from your OBD1 loom plus the purple/white connector for the ecu. Between now and the sale i'll try and improve its appearance!
Quite heavy so postage will be around 15. Collection preferred
List Date: 7/10/2014
For more info, click here to view the original listing: OBD2 engine and injectors looms
On Sale For: ?85.00
the-corrado-forum
Mobile friendly version: OBD2 engine and injectors looms
can you pm me your contact details so i can come and see it. Ive got to go over to perivale some point this week during the evening so can come past you as well
