Roger Blassberg 0 Posted September 28, 2014 Passat B4 estate glass sunroof is now in. It fits well, very slightly high (less than 1mm) at the middle front which I will try to minimise by adjusting the panel but the main thing is that IT TILTS AND SLIDES !! And the bonus is that all sorts of interior rattles have disappeared as well which must have been emanating from the old sunroof. The sliding blind is a perfect colour match (beige). There is hardly any wind noise and all I have to do now is get the headlining back in without breaking it. Last thing on the list is to get the A/C working. Best wishes RB Quote Share this post Link to post Share on other sites
ryan_welshman 10 Posted September 28, 2014 Followed the guide that was linked to here, moonroof is installed and working :) Quote Share this post Link to post Share on other sites
j_s14a 0 Posted September 28, 2014 I've got a late '90s SEAT Ibiza moonroof in mine, but due to struggling to find a decent motor, I have kept the manual winder in for now :D The Corrado panel fits in the SEAT mechanism too, but you have to use the matching inner trim, the sliding sun blind from the Ibiza roof won't work with the Corrado panel, and vice versa. Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted October 12, 2014 I put the roof lining back in today, having given it a good clean with Vanish carpet cleaner. Just to make sure that it didn't get damaged, I reinforced the back of the two rearmost tabs and the surround to the interior light/electric motor panel at the front; I bonded some thin plastic, (actually a piece of food container cut to size and bonded on with superglue to the back of the liner). I replaces the foam strips, which had fallen to pieces, with 3mm thick rubber draught excluder from Homebase. Hopefully this will prevent rattles and creaks. Best wishes RB Quote Share this post Link to post Share on other sites
Mike2006 0 Posted February 2, 2015 When fitting a glass roof from Passat, what seal do you use? Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted February 3, 2015 I used the seal that was already on the B4 Glass panel. Ian. Quote Share this post Link to post Share on other sites
