awigman 0 Posted July 14, 2014 My second post of the day requesting help! My spoiler seems to operate fine when it rises however when it lowers automatically it drops a little then stops. When you lower is manually its drops a little, stops then you hear a tick (presumably from a switch) then drops a little bit more, then ticks then a little bit more and so on and so on until its all the way down. Any advise? Thanks Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted July 14, 2014 Two choices by a brand new motor or bypass the green thermal fuse in the motor Quote Share this post Link to post Share on other sites
johnnyfication 0 Posted July 14, 2014 It could just require stripping and cleaning. Mine did the same, so I stripped it down and cleaned and re-greased the motor + complete mech. It now works perfectly. Word of warning it can be fiddly to put back together, but if you take your time it will go. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted July 14, 2014 When it clicks though it means the thermo fuse is on its way out Quote Share this post Link to post Share on other sites
dragon green 6 Posted July 14, 2014 Give it a good clean,what is there to lose ! http://the-corrado.net/showthread.php?t=51125 Quote Share this post Link to post Share on other sites
Roger Chatfield 0 Posted July 14, 2014 As above, I had the same problem with mine, removed it, stripped it down and gave it a good clean, now works fine. I did notice a fair bit of copper dust in and around the motor commutator, this may have been causing shorts and hence tripping the thermal fuse. Rog. Quote Share this post Link to post Share on other sites
