Nick_Micouris 0 Posted June 6, 2004 I have a wierd knocking/whirring sound coming from my bl**dy car now!! Whilst on the move... Not mechanical but seems to come from the suspension side of things. Can bearings knock?? It can be felt through the floor but not the steering wheel. coincidentally this is after fitting a set of refurbed alloys and new tyres. I thought they may be imbalanced but it seems that I get no vibration through the wheel but rather a knocking (vibration) though the car! This is only noticeable at slow speeds by the way!... Quote Share this post Link to post Share on other sites
vr6storm 0 Posted June 6, 2004 you have checked that your wheel-bolts are on securely nick? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted June 6, 2004 Not just the wheel bolts, but check the rims for any dents or flat spots. Quote Share this post Link to post Share on other sites
Nick_Micouris 0 Posted June 6, 2004 the rims look utterly round and the bolts are tight :( :? I suppose I could get the wheels balance JUST to be sure!? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted June 6, 2004 Make sure nothing's dragging too - if you've put smaller wheels on or something, it might be catching somewhere. Quote Share this post Link to post Share on other sites
Nick_Micouris 0 Posted June 6, 2004 That's the wierd thing. They are another set of Speedlines just refurbed. I don't know if the tires could just be a harder compound and therefore noisier making a "knocking sound" ? The tyres are BF Goodrich, the old ones were Goodyear. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted June 6, 2004 Put the old wheels back on.. If it goes away you know where you stand. It could be something stupid like something inside the tyre when they fitted it... Quote Share this post Link to post Share on other sites
coolrado 0 Posted June 6, 2004 i had my wheels balanced once and they put the balance weights in the wrong place and they caught on the callipers :roll: .....might be worth checking. Quote Share this post Link to post Share on other sites
Nick_Micouris 0 Posted June 6, 2004 will have a fiddle tomorrow! cheers guys I may just get them balanced and that way I can rule out the wheels being a problem Quote Share this post Link to post Share on other sites
Nick_Micouris 0 Posted June 8, 2004 Found out what the knocking was..... THE INNER CV joint on the drivers side. You can tell by spinning the drivers side wheel - it knocks with every rotation. This is probably why it is more noticeable at slow speeds! NOW - I will tell you a story.... Some time ago I had my local stealership replace my clutch on a private job - very cheaply. All was good until I was tinkering under the car one day and noticed that all of the bolts on the inner CV joint boot were loose. :shock: I mean they were coming out!! They had actually split the rubber and the grease had all gone. I was lucky I noticed it. Anyway - I kicked up a fuss and they weren't willing to help much as it was a private job, but they agreed to replace the rubber boot..... Anyway - I guess the lack of grease actually damaged the CV joint so I had better change that asap.... I have a pic of the loose bolts and damaged gaitor somewhere, must show it. Anyway - dont bother getting work done at the stealers!! :evil: Quote Share this post Link to post Share on other sites
stel g60 0 Posted June 8, 2004 its the age old saying nick, you want it done properly, you got to do it yourself! aint much different from a dealer and a backstreet cowboy except a badge! Quote Share this post Link to post Share on other sites
Nick_Micouris 0 Posted June 8, 2004 TRUE TRUE! what I got tired of was the mechanic reasoning his mistake by saying "In all honesty we don't see many of these cars"..... pathetic :lol: :roll: Quote Share this post Link to post Share on other sites
dr_mat 0 Posted June 8, 2004 "in all honesty it never occurred to me that the CV might be knackered if it didn't have any grease in it"! LOL What a bunch of prime ARSE! :) Quote Share this post Link to post Share on other sites
