robrado974
Ebay HT lead removal tool
My advice would be to get one from Tps or VW if you need to get one . I service my car at the end of every summer regardless of weather it needs it or not . Today I must have set a world record for the slowest plug change ever , not that there's any rush but using the ebay one is a bit of a pain . I find that even with the lugs located , the head of the lead gets pushed up the tube , making it a struggle to pull the tool out leaving the lead attached to the plug . It must have taken eight to ten attemps to finish each plug . I ended up getting a pair of pliers and crushing the tool so the lead did not keep getting caught . Just a little heads up .
Regards
Rob
It worked ok the first time , which was around two years ago Chris , then it became harder to use .
Jon , yeah it's the metal one .
