heyzy
Top suspension mounts
My VR had a weird nocking noise at low speeds.I jacked the car up in the middle and it seems that one of the top suspension rubbers is completley nackered (loads of play).Has anybody else experienced this?and what would anybody recommend changing too. ie standard etc. Thanks
There will be loads of play if there's no weight on the wheels - it'll hang from the suspension strut top mount.
That said, if you're handy with the spanners, just swap them. They're not too expensive, but a garage will probably charge at least an hour to swap the pair for you.
You can actually see the top top of the strut move about an inch.On the other side it seems to just rock a little.Thanks for your advice.
That's pretty extreme! Yep, swap em!
If he swaps them won't he then have the same problem on the other side? :roll: :lol:
