mimjed 0 Posted December 3, 2014 Don't know if it's been covered before, but my sunroof gets a burst of power every time I lock the car. Starts to tilt up. Very annoying! Any clues how to stop this? Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 3, 2014 Mine does this a little bit only every now and then. Just think its normal Quote Share this post Link to post Share on other sites
mimjed 0 Posted December 3, 2014 Lock it 4 times and its an inch in the air?? Quote Share this post Link to post Share on other sites
KipVR 1 Posted December 3, 2014 That'll be the full closure module with your alarm, turn the sensitivity down on it. Quote Share this post Link to post Share on other sites
mimjed 0 Posted December 4, 2014 Haha concerning, don't think it has an alarm anymore. It's on its second conversion. Any clues on the process and the hidy hole for the module? Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted December 4, 2014 Ah mines not that bad Quote Share this post Link to post Share on other sites
KipVR 1 Posted December 4, 2014 The vw alarm module and the closure module are two separate items, usually hidden up by the glovebox. I may have a spare module if yours is playing up. Quote Share this post Link to post Share on other sites
KipVR 1 Posted December 4, 2014 They were always badly wired up, because the dealers fitted them! Quote Share this post Link to post Share on other sites
mimjed 0 Posted December 5, 2014 may well be needing on then...i only have a dash shell in at the mo, so shouldn't be too hard to spot. failing that just pull the power to the sunroof motor i guess. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 5, 2014 Is it not because you need to resync the full closure? Corrados have that anyway, regardless of any alarm fitted (I think?). The reset procedure is:- 1) Close the roof either by hand or with the motor. 2) Drop the motor but leave it connected 3) Get out of the car, close the door and then lock the door with the key. Do a lock and hold as if doing a full closure. 4) If the motor was out of sync, you'll see the pinion gear turn a few times and then stop. 5) Refit motor and all should be well. If the motor just twitches and the pinion doesn't move. It's already synced and the problem lies elsewhere. Quote Share this post Link to post Share on other sites
KipVR 1 Posted December 5, 2014 You might be right there Kev but I figured if it was out of sync it would just stop in the same wrong position every time rather than ratcheting out with each attempt to shut it? Quote Share this post Link to post Share on other sites
mimjed 0 Posted December 6, 2014 Most likely is out of sync as it doesn't stop level with the roof on the button, bottoms out and then stops. Cheers kev, sounds like another job on the Sunday list. Quote Share this post Link to post Share on other sites
KipVR 1 Posted December 25, 2014 Did you fix this? Quote Share this post Link to post Share on other sites
mimjed 0 Posted December 30, 2014 haha no, tried kevs method 3 times and it still didn't want to play the game. just disconnected the power to the motor instead. shame as it both tilts and slides as it should, but i never really saw the great use of a sunroof anyway so no great loss. Quote Share this post Link to post Share on other sites
seanl82 23 Posted December 30, 2014 Mine has started doing this the last couple of days. Its the first time its been used since I replaced the mech and motor, although all three motors I've tried still only tilt and don't slide. Opens perfectly and smooth when operated manually. I was going to try Kevs method tomorrow actually. I make a habit of lifting it slightly on the switch before locking the car now. Quote Share this post Link to post Share on other sites
mimjed 0 Posted December 30, 2014 yeah its worth a bash, if you figure it out let me know!! theres a video on youtube of some dude whos changed all mechs and motor. he shows you a different way how to set the motor (granted i didnt try this though) Quote Share this post Link to post Share on other sites
