Mk3highline 10 Posted December 12, 2014 Well I hope I have more than 140ft lbs lol on stealthy rollers Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted December 12, 2014 I hope you have decent running shoes on as that's quite a feat. :lol: Are you testing the car as well while you're there? Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted December 12, 2014 Yeah it's been done got a problem with the cam position sensor which needs sorting with some det post up a graph shortly got one run with the flaps on and off overlayed Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted December 12, 2014 Well obviously with the 12v obd2 ECU standard map with the flaps closed was 197bhp @6100 rpm With the flaps open it was 229bhp @ 6353rpm Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted December 12, 2014 229 is good going! Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted December 12, 2014 I couldn't believe it, still don't lol The graphs are up on the 24v thread With the flaps open I got torque all way to rev limiter So I guess once the cam sensor problem is solved and mapped it should be ok Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted December 13, 2014 Open flaps = :) Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted December 13, 2014 Got a new cam sensor Wired in new plug for sensor, problem I have is laptop has died and not got another laptop to use the vag com with Got a cheepy scanner but it has never shown the cam sensor fault Reset ECU so will see if there is anything different now on my way to work later Quote Share this post Link to post Share on other sites
Mk3highline 10 Posted December 14, 2014 Things only go from bad to worse It's a lot trickier to drive on slight icy roads Ferodo pads and wave diff are desperately needed too There was me over excited yesterday and now I can't believe the difference with a working cam position sensor It's insane Quote Share this post Link to post Share on other sites
