dickie 0 Posted January 5, 2015 Hi, my passenger door seems locked, doesn't matter if you lift the door pin it drops back down. Anyway of opening it? Thanks Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted January 5, 2015 If you can get the window down you can get a bit of bent rod in there to lift the lever near the shutting latch. It's fiddly though. Quote Share this post Link to post Share on other sites
dickie 0 Posted January 5, 2015 Yeah window works perfectly so it's an option! Quote Share this post Link to post Share on other sites
MarkFoster 0 Posted January 5, 2015 If you disconnect the pump in the boot and leave it for 20 mins (or pull off one of the vacuum hoses)the pressure on the actuator will deplete and you'll be able to simply pull up the pin as normal. When mine did this I fitted a new pump which seemed to sort out the problem and it's been fine ever since. HTH. M. Quote Share this post Link to post Share on other sites
dickie 0 Posted January 5, 2015 Good idea! There's a few connections that could be dis connected. Cheers. Quote Share this post Link to post Share on other sites
