fla 9 Posted January 16, 2015 The digital displays in my clocks disappear when the ignition is switched off, similar to disconnecting the battery. Time is still correct, but i dont know about the trip meter as the car is not running yet. Any suggestions? Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted January 16, 2015 Sounds like your continuous 12v, isn't! Quote Share this post Link to post Share on other sites
fla 9 Posted January 16, 2015 Thanks sean. Do you know which wires I need to check? Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted January 16, 2015 Only thing I can recommend is to get the multimeter out on the instrument plug and see what you find. If you find the electrics ok, it points towards the cluster being bust. Quote Share this post Link to post Share on other sites
fla 9 Posted January 17, 2015 Fuse 21 blown, now sorted. note to self: check the obvious things first before suspecting the worst! Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted January 17, 2015 Got to love an easy fix! Quote Share this post Link to post Share on other sites
