Davidjhopkins 10 Posted January 30, 2015 Ok so my situation is this. Drivers door doesn't open from outside anyway.(part ordered). My key doesn't seem to operate the passenger door or boot. Which was fine because my central locking fob worked. But now that has stopped working. Could it maybe because the temperature has dropped? I can no longer see the immobiliser flashing from within the car. Could this mean something? Please help, desperately need to get into my car for work tomorrow morning. Quote Share this post Link to post Share on other sites
Jim 2 Posted January 30, 2015 What year is your Corrado? Quote Share this post Link to post Share on other sites
Davidjhopkins 10 Posted January 30, 2015 1994 vr6 Quote Share this post Link to post Share on other sites
Jim 2 Posted January 30, 2015 Later cars have full closure built into the door locks - so if you turn your key to the lock position, it winds up the windows. I'm trying to think if it works the other way - so if you turn it to the unlock position, whether the windows will drop? Worth giving it a go I suppose! Quote Share this post Link to post Share on other sites
Davidjhopkins 10 Posted January 30, 2015 Tried turning the key all ways in the passenger side. No joy at all. Key won't even go into the boot lock. I'm guessing I should have been given a different key for that. Quote Share this post Link to post Share on other sites
Davidjhopkins 10 Posted January 30, 2015 Just tried the drivers side. Doesn't do anything g either. Quote Share this post Link to post Share on other sites
Jim 2 Posted January 30, 2015 Bummer :( You might have to call out breakdown to 'break into' your car :( Quote Share this post Link to post Share on other sites
Davidjhopkins 10 Posted January 30, 2015 Only just got breakdown cover haha. Can't use it for 24 hours so I guess I'll just have to wait until then. Will they be able to 'break' into my car? Or just tow it to a garage? Quote Share this post Link to post Share on other sites
Jim 2 Posted January 30, 2015 Yeah should be able to - I don't think Corrado's are especially difficult for professionals to get into unfortunately :) Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted January 30, 2015 Brick!! harsh...but true lol Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted January 30, 2015 You should be able to get something in the door if you remove the rubber window scraper trim from the top of door/bottom of window. You want to be trying to reach the latch and lift up the lever. Is one for the lock and another does the latch. Very fiddly though. I've broken into many a thing using the metal bit off those paper files that site in filing cabinets. This sort of thing, is a thin metal bar you can rip out and has a handy hook on the ends. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted January 30, 2015 I've broken into many a thing using the metal bit off those paper files that site in filing cabinets. is there a confession you need to make Jim ;) lol Quote Share this post Link to post Share on other sites
Ray1965 10 Posted January 30, 2015 Mine did the same with engine running. Decided to lock it's self and i had no spare key. 45 mins ticking over on drive. Gas man visiting next door took 2 mins to get in with the looped wire trick through the rubber. Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 30, 2015 I did the same once, but called a pro as I didn't want to scratch my paintwork getting the wire down to the pin. Guess what, he scratched the shiz out of the paint at the edge of the roof/top of the door shut. Grrrrr! Quote Share this post Link to post Share on other sites
Portent 0 Posted January 30, 2015 The keys are obviously mismatched and I'm guessing the battery has died in the cold, hence no remote (un)locking. I'm wondering whether it would be better to try to get into the engine bay to charge the battery? e.g. if is possible to release the bonnet catch from underneath somehow? Or a replacement grille from a breaking car may be cheaper to replace than a new window or possible scratches on the paintwork. Quote Share this post Link to post Share on other sites
Stonejag 10 Posted January 31, 2015 Agreed, I would take the grille out and try to release the bonnet that way. I've seen it done from below the car but you need a very skinny arm and preferably a 4-post lift! It's possible to get the grille out without breaking any of the clips but it's not easy. They're only £20 anyhow. Could always try some WD40 in the boot lock, the design of the back of the car tends to suck dirt up into them. Of course if it's a different key that won't help... Full-closure doesn't open the windows during unlock, sadly. Quote Share this post Link to post Share on other sites
Drucey 10 Posted January 31, 2015 They are very very easy to break into :-( Quote Share this post Link to post Share on other sites
Wullie 1 Posted February 3, 2015 Couple of days too late probably but I've found this works. http://guyviral.com/auto/man-hacks-unlock-car-truck-just-shoelace/ Needs a bit if practise to get this good but some patience wil get you in. Quote Share this post Link to post Share on other sites
