Wayne2015
White VR6 in Windy Yorkshire! :)
BAD news!
VERY BAD NEWS :( :( :(
Chris just rung
1. No coilover keys to increase height
2. Oil leak
3. Radiator leak
££££££ ?????? EEEEEEK!
dont panic Mr Mannering!
coilover adjustment - probably just need a standard C spanner
oil leak - where from? - could just be a tiny seal
radiator leak - rads are not that expensive but the labour would be a few hours. its not that tough a job but a tad scary once you have the front end off in bits lol (i changed mine myself & managed to get one of the last genuine VW ones)
FYI i would recommend NOT using any rad seal or similar product though! IIRC i believe the VR has very small channels in the block which are designed to circulate the coolant & using a rad seal type product can cause these to get blocked & effect the cooling system
have you asked them to look at your running gear? IE CV boots/joints, drop links, tie rod ends, wishbone bushes, rear beam bushes etc
from my experience it is those type of jobs that can be expensive as they are pretty labour intensive & as with cars of such ages time can be burnt just trying to get the damn things apart lol
Cheers guys
And thanks for offer of spanners,
But
Its not going to help me on the road :(
The STALLING will continue and i do NOT want to drive it risking my kids lives :( :( :(
Its come back with like £200+ fix for the stalling - but parts needs to be ordered.
My mini tour down south has been torpedoed now :(
Will have to drive the Prelude now.
Great car with 4WS :)
But the plan was to drive the Corrado :( :( :(
HUGE oil leak!
But nothing drips on floor!
Sump plug / sump WHACKED!
So not sure if sump plug will screw back in???
Coolant leak from radiator
See middle top left corner of rad?
Exhaust hanging lose (clip broke)
Coilovers
Right
Bringing out the Prelude for the mini tour then this Sunday - Tues (West Yorkshire - Bournemouth/Portsmouth) ...
Much MUCH less fun - but it will do ... :(
Prelude looks good, probably have less fun with things not going wrong with it .
What's happening with the Corrado then? Is that still at the garage having the work done or is all that on hold for now
Cheers guys!
Garage going to source all the parts and hopefully fix within the next week (1/2 term).
Aftermarket radiator (no more from VW)
New sump
New lambda sensor
4 wheel alignment (apparently my front wheels are angled for track racing?)
Increase coilover heights
Secure exhause
Trouble shoot oil leak
Oil / filter change
Trouble shoot yo-yo rpm in the mornings
Over all inspection of car ...
Right
FEETS back on the ground now!
This NEW garage bill has made me think about going to Stealth Racing for the Timing Chain etc
Need to see if I can still finance it now ... :(
Right
At least you've saved the cost of a new battery, :norty:
And welcome to the world of Corrado. All seems ok on the surface, but those brave enough to look further tend to wish they didn't!
Cheers Saen
I swear there was NO oil NOR coolant leak when I bought it and the ONLY time it leak was coolant ONCE the other day :(
Yup!
Cheers Stuart for checking the battery was fine and charging :thumb right::thumb right::thumb right:
Cheers Saen
Trying to keep up with a valver may have pushed it over the edge, :p
:lol::lol::lol:
Thinking of getting my car remap - so u may have to upgrade your engine before we next meet, Stuart! :norty:
By the way,
How did my car sound when I overtook?
Just make sure they do the coil over height before messing with setting up geometry, other wise you'll have to do the fronts again. I don't believe there is anything to adjust on the back unless they think the subframe has moved??
Cheers Tiger
The garage do not have the alignment equipment.
But he did say
He would do the coilovers first
Then take it round to a local garage with 4 wheel alignment equipment
- this local garage also would straighten the front ANGLED wheels
the back wheels got spacers (hence sticking out of arches)
- hence rubbing into wheel arches and cutting into tyres
But garage also said the spacers looked THICK
So possibly if removed the wheel then may hit the inside of the wheel arches/coils :(
Well
School 1/2 Term mini tour in my Prelude (no Corrado as planned :( )
Hooked up with a fellow Prelude forum member in Southampton :)
Then met Seanl82 (the really nicest most helpful top guy one can ever meet!)
Then fish n chips on Hayling Island beach with kids :)
